Dear Audacity Team member/experienced User;
I hope you can help me with a problem I’ve been having since I can remember with Audacity.
I’m an amateur musician and I’d like to record some of my songs/covers on audacity, but I’m repeatedly having this problem:
I’m using a normal headphone/microphone set to record my music. I put on my headphones, move the microphone to in front of my mouth, press record, and sing. When I’m done, my ‘recording’ looks like this:
So, I amplify it by as much as I can, and it ends up looking like this:
After deleting the front bit (
) which was stopping me from amplifying further, I amplify as far as I can again, and my recording looks like this:
This is where my problems really begin, and they are twofold;
1. Firstly, the recording is below the 0.0 line, and since i don’t really know what this bit (
) is, I don’t really know how to change that.2. Secondly (and I think if problem 1 is solved, so will this one), there are clicks in my recording which I think could be removed by the Click Removal plugin, but that’s not working. I assume that if the recording did sit on the 0.0 line which I mentioned previously, that the Click Removal would work.
The recording does play, and sound does come out, but these two problems mean that I can’t really publish or edit the recording further, as it is displaced and littered with regular clicks.
Can you help?
Regards,
Fiona
