recording stops working
JamesFarrow
Post by JamesFarrow » Sun Jun 24, 2012 6:34 pm
Hey
when I'm recording randomly it will cut out for like 1/8th of a second and nothing will be recorded then it goes back to recording normally
how do I fix this problem?
thanks
-James
JamesFarrow
music skips
Post by JamesFarrow » Sun Jun 24, 2012 10:25 pm
While recording with my steinberg CI1 on windows 7 64bit the music will skip but it makes a noise before it does and then it dosent pick up any sound for a fraction of a second is their a way to fix this? i tried lowering the audio quality to 16 bit but it dosent help I uploaded a pic of what happens
Reason: Topics merged
Re: recording stops working
Post by steve » Mon Jun 25, 2012 12:10 am
JamesFarrow
Post by JamesFarrow » Mon Jun 25, 2012 12:47 am
I have already went through that list and and been able to complete most of this list but it hasn't helped at all is their anything else that I can do?
Post by steve » Mon Jun 25, 2012 12:52 am
How often do these gaps occur?
Can you see any pattern to when they occur?
JamesFarrow
Post by JamesFarrow » Mon Jun 25, 2012 12:55 am
their is no pattern sometimes it happens twice within a few seconds and other times it wont happen over a minute
Post by kozikowski » Mon Jun 25, 2012 1:00 am
Do you have Sound Activated Recording clicked on?
Edit > Preferences > Recording > Sound Activated Recording. If you have a quiet space in your recording, that's likely to stop recording and then pick up again.
Post by kozikowski » Mon Jun 25, 2012 1:06 am
This doesn't have a wall power supply, does it? It gets all of it's operating voltages from the USB cable? Are you going through a USB Hub with other stuff? USB Audio hates that and it will put holes in your music. Try a different USB connection on your computer, or just pull and plug the existing one a couple of times.
Post by steve » Mon Jun 25, 2012 1:09 am
Carefully check through what applications and processes are running on your computer. Close all non-essential applications and stop all non-essential processes, then make a test recording.
JamesFarrow
Post by JamesFarrow » Mon Jun 25, 2012 1:11 am
Sound activated recording is not on, yes their is no power hub the CI 1 gets all its power through the usb cable that is plugged directly into the back of my computer i have tried switching usb ports but it dosent seem to make a difference
