Recording from another site ?
john2010
Post by john2010 » Sat Jun 23, 2012 12:54 am
hello, first post..
Just wanted to say you guys did an awesome job with this software. I find it much better than others, and free ? can't beat that.
just wanted to ask if there's a way to record sound effects from other sites. for example, there's this one mouse-over sound effect from another site that i'm very interested in. It's only like a second long.
would I be able to use your software to record that and keep the quality good ? I just the option for "Sound Activated Recording On / Off " and was wondering if maybe that could be used as well ?
If you think this software won't help at all in trying to accomplish what I want done (recording that sound effect) , and additional help or other software recommendations to get the job done will be much appreciated.
thanks
John
Re: Recording from another site ?
Post by kozikowski » Sat Jun 23, 2012 4:28 am
Audacity isn't the problem. Audacity will record anything Windows presents to it. It's the presenting part that gets you into trouble.
http://manual.audacityteam.org/help/man ... puter.html
