It is possible to make a female voice sound as male without
nashoomoo
Post by nashoomoo » Thu Jun 21, 2012 2:52 pm
I can try to change pitch; the problem is that it also changes the instrument. Is there a way to detect just that female voice to be taken out, or to be changed for male voice?
Re: It is possible to make a female voice sound as male with
Post by kozikowski » Thu Jun 21, 2012 3:24 pm
It is difficult or impossible to do Vocal Isolation and Difficult or Impossible to change a human voice to anything else.
The Vocal Removal plugin can sometimes remove a voice, but usually fails more often than it succeeds.
http://forum.audacityteam.org/viewtopic ... 75#p183375
There is no good software for Vocal Isolation --remove everything but the voice
Simple tools for Voice Change fail because some parts of a voice like SSS and FFF and plosives do not change from person to person, but the pitch and timbre does. Simple tools change everything and make the voice sound funny.
nashoomoo
Post by nashoomoo » Thu Jun 21, 2012 11:48 pm
I need it for me, I need it for me so it will be good, even if sounded funny. I will try, and post
reply.
Post by steve » Fri Jun 22, 2012 8:24 am
nashoomoo wrote:I can try to change pitch; the problem is that it also changes the instrument. Is there a way to detect just that female voice to be taken out, or to be changed for male voice?
No, that can't be done.
The first problem is that separating one voice from a mix leaving both the voice and the music in tact is virtually impossible,
The next problem is that you can't change the "character" of a voice using normal audio processing - you would need complex formant processing to do that, which is a highly specialised field in voice processing. Even specialised, state of the art voice processing software can't do that without it sounding a bit strange.
