Can't export as WAV or AIFF file.
Fgmaniac
Post by Fgmaniac » Thu Jun 21, 2012 1:02 am
I'm using Audacity 2.0.0 on Windows 7 x64 SP1 (Home Premium) . I haven't had this problem before, but all of a sudden I cannot export as a WAV file. I tried using AIFF instead, but it didn't work eaither. The error for the WAV file is;
"Error while writing WAV (Microsoft) file (disk full?). Libsndfile says..." Then it says a bunch weird accents, symbols and that box used when you don't have the text (I'm assuming gibberish)
I can use FLAC, and just convert, but I'd really like to get to the root of the problem. I've tried re downloading, changing names and I do have HD space. Please, can anyone help me?
Re: Can't export as WAV or AIFF file.
Post by kozikowski » Thu Jun 21, 2012 1:53 am
You may have run into the filename problem. Don't put dates or other punctuation marks into your filenames. It can drive the computer nuts. Today is not 6/20/12, it's 20120620. No slashes, no periods, no commas, etc.
Post by steve » Thu Jun 21, 2012 2:45 am
Fgmaniac wrote:"Error while writing WAV (Microsoft) file (disk full?). Libsndfile says..." Then it says a bunch weird accents, symbols and that box used when you don't have the text (I'm assuming gibberish)
That usually indicates that there is invalid metadata.
Go to "File menu > Open Metadata Editor"
Then click on the "Clear" button, then on the "OK" button.
Then try exporting.
Fgmaniac
Post by Fgmaniac » Thu Jun 21, 2012 9:53 pm
Thank you Steve, it worked! Strange though, because the Metadata was empty to begin with. Nonetheless, kudos for fixing my problem!
Post by steve » Fri Jun 22, 2012 1:55 am
Fgmaniac wrote:Strange though, because the Metadata was empty to begin with.
Probably not quite "empty". There was probably a bit of "invisible garbage" in there causing the problem.
Glad it's working now :)
