Suggest sound card for recording ~$200
I guess many members of this forum are professional sound editors or like so I want to ask what sound card they use for recording and why (briefly)?
I started looking at firewire devices (for easy installation and to have compatibility for future system) but prices seem way far from my budget.
One of my problems is that many of US, EU or UK merchants don't deliver to Australia, but you please suggest a card anyways so I could decide for my next buy and even if it's a bit more expensive than my badget.
Re: Suggest sound card for recording ~$200
Since you didn't post a job or type of recording, I would recommend our ever-popular Behringer UCA202. $30 USD. It does a very good job of stereo input/output and it has a headphone jack that allows you to perform perfect overdubbing/multi-track if you need that. It allows you to use cheaper analog mixers and existing sound equipment like I'm doing here.
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
I have one and we use several at work.
For most of my "pro" work, I use the very good quality soundcard built into my Mac.
Thanks for help, I love Behringer products as I own beautiful monitor speakers and their price is unbeatable for the quality they offer.kozikowski wrote:Since you didn't post a job or type of recording, I would recommend our ever-popular Behringer UCA202. $30 USD.
However, I did a quick search for the UCA202 and indeed it's a well regarded interface (especially if compared with its price) but I think that from my average budget of $200 I could look at more expensive interface?
My main use would be recording audio from hi-fi cassette audio player (line signal), recording computer's own sounds from any sources (mixer settings from audio properties) and so on.
Are these my 2 different requirements (line signal and software mixer) incompatible with the interfaces?
For recording Sounds Made on the Computer, you don't need an external interface at all. That's the desperation method and you're far better off if your computer doesn't feature Stereo-Mix, to invest in one of the software packages that allows this without leaving the computer.
As far as converting music cassettes like this...
http://kozco.com/tech/audacity/pix/UCA202.jpg
In my opinion, whatever tiny shortcomings there are in the adapter are far outweighed by the noise and distortion of cassette tape. There are much larger and more complex adapters, but the only thing extra you get is the ability to change volume. People have noted under certain conditions that is required. Other elves need to post because I have no experience with them. I go straight to a microphone, mixing board and my Mac which has a terrific digitizer, or straight to the Mac if I'm converting vinyl or cassettes. It's only if you're on Windows or Linux that you're much more likely to require the adapter.
Since vinyl or cassettes are a thing of the past, I assume you have only a definite, even limited set of cassettes to digitize.
So instead of making life more complicated than it needs to be trying to create a permanent cassette-deck-to-laptop set-up, why not temporarily borrow (use) a desktop PC from a friend, and create a line-out/line-in set-up between your cassette deck and the PC? All you need is a good hi-fi cassette deck, a PC with a reasonably good sound card, the appropriate line-out/line-in cord and jacks, and Audacity. This is exactly what I did myself. The results were amazingly good. The original noise and distortion of cassette tape simply cannot be heard in the digital output (FLAC files saved from Audacity). Somehow they got filtered out in the process.
For external sound cards, recording the computer's own sounds in Audacity is generally not supported on Windows unless you use a loopback connector (connect a stereo audio lead from the line out to the line in).
For recording tapes/mini-disks etc. it is useful to have recording level controls (which the Behringer UCA 202 does not have).
There are plenty of options available that are well within your budget.
ART USB devices have a good reputation for being solidly built - for example the ART Tube MP project series USB Preamp which also includes a nice pair of microphone inputs.
Alesis have a good reputation for value - the Alesis IO|2 Express may be of interest.
M-Audio are a big name in this price range, but I've often found the Windows drivers to be a bit unreliable and since they merged with Avid/Digi Tech I've found their customer support to be very poor so personally I'd not recommend their USB devices (your mileage may vary).
I read somewhere that often standard computers' internal audio devices are just averagely good for the digital to analogical sound conversion such as during gaming or listening at music and so the device (or worse when is an onboard chip) doesn't have a good analogical to digital conversion capability in my case the recording.kozikowski wrote:For recording Sounds Made on the Computer, you don't need an external interface at all.
I mainly use a desktop PC and of course it has the line-in socket.
I am still not clear what the benefit is by using your suggestion, the Behringer, does it just swap the signal from analogical to digital or it actually properly digitize it so no work is after the computer?
This is exactly what I did but I'm looking at a specific device to improve recording from analogical external sources.Robert2 wrote:Since vinyl or cassettes are a thing of the past, I assume you have only a definite, even limited set of cassettes to digitize.
Finally, you got right to the point.steve wrote:For external sound cards, recording the computer's own sounds in Audacity is generally not supported on Windows unless you use a loopback connector (connect a stereo audio lead from the line out to the line in).
But I see these devices are mainly aimed at instruments such as guitar or microphone (I would need to use adapters from computer for their slots) so is this the right thing for me to do?
Or should I look at PCI style internal cards like this one: http://www.turramusic.com.au/Handler.as ... L&CIID=356
I remember what you said about M-Audio but I just want to understand what is the best solution for my work then I choose the optimal product.
