Suggestion: multi-function button for Record/Play
Caps
Post by Caps » Mon Jun 18, 2012 11:29 pm
The transport – the play and record button should be the same button. When you stop, the record button should show “Play” when you hit the “Pause” button the record button would show “Record” or “Rec continue.”
Re: Suggestion: multi-function button for Record/Play
Post by kozikowski » Tue Jun 19, 2012 12:36 am
When you stop recording, you have the option of recording again onto a new track. Koz
PGA
Post by PGA » Tue Jun 19, 2012 6:50 am
Caps wrote:The transport – the play and record button should be the same button. When you stop, the record button should show “Play” when you hit the “Pause” button the record button would show “Record” or “Rec continue.”
The transport buttons in Audacity mimic those found on analogue tape decks. They are a standard that sound engineers can relate to.
