Need help removing ringing background sound
MaryM
Post by MaryM » Fri Jun 08, 2012 5:57 pm
Hi, I'm using Audacity 2.0 on Windows Vista 32-bit. I'm new to using Audacity for more than the simplest tasks. The attached audio sample was originally recorded on a cassette recorder in the 1980's. There is an annoying ringing in the background. We created an mp3 and used it for copyright registration, but need to improve the quality before issuing the whole song on a CD. I cannot use Noise Removal because the sound cannot be isolated by itself. Is there any way to remove the ringing sound without destroying the guitar and drums? Thanks!
sample with ringing in background.wav
(669.65 KiB) Downloaded 391 times
Re: Need help removing ringing background sound
Post by steve » Fri Jun 08, 2012 7:34 pm
Try using the Equalization effect http://manual.audacityteam.org/manual/h ... ation.html
Select the "Graphic Eq" view, and pull down the 3.15 kHz slider to the bottom (all other sliders set "flat" at 0 dB).
MaryM
Post by MaryM » Sat Jun 09, 2012 5:03 pm
Thanks for the suggestion. I tried doing the equalization as you described but it didn't remove the unwanted sound. Any other ideas?
Trebor
Post by Trebor » Sat Jun 09, 2012 8:58 pm
MaryM wrote:.... I tried doing the equalization as you described but it didn't remove the unwanted sound. Any other ideas?
Deeper notches in the equalization are possible if you use the "draw curves" option rather than using the "graphic EQ" sliders which are limited to -15dB ...
big notch at 3KHz-.png (45.09 KiB) Viewed 6352 times
A deeper notch removes more sound ...
[ BTW it sounds like you' could have got some sort of feedback problem with the guitar which has a resonant frequency of 3KHz, this could be an electrical or acoustic feedback loop : somehow feeding some of the output back into the input ]
555555
Post by 555555 » Wed Jul 04, 2012 5:23 am
Same thing here, This was a very low sound recording through 2 walls. The high pitched ringing is louder than the conversation.
How can I remove the noise? :?:
Post by steve » Wed Jul 04, 2012 12:07 pm
555555 wrote:Same thing here, This was a very low sound recording through 2 walls. The high pitched ringing is louder than the conversation.
Rather than trying to remove the noise, the better solution would be to place the microphone in the same room as what you are trying to record after ensuring that you are legally entitled to do so.
If the noise level is greater than the signal level then there is probably not much chance of successful noise removal, but if the high pitch ringing is at specific frequencies then you may be able to "notch them out" as described by Trebor. See here for how to identify the frequencies that may need to be filtered out: http://wiki.audacityteam.org/wiki/Noise ... tch_Filter
555555
Post by 555555 » Wed Jul 04, 2012 2:36 pm
[moderator note: link removed]
next-door-are-fighting-again
Post by steve » Wed Jul 04, 2012 3:37 pm
555555 wrote:[moderator note: link removed]
I'm not a legal expert, but it is probably a breach of privacy laws in many countries to record your neighbours and publish the recording on the Internet without consent.
Also the recording quality is so poor that it would not be possible to recover anything other than a bit of "distant noise" from that recording.
