Generate -> Click Track [ 1.3.6a6 ]
Building and customizing Audacity from the source code.
smarmit
Post by smarmit » Fri Oct 03, 2008 2:33 am
Hi all:
I just compiled (win32:Release) 1.3.6a6 with WxWidgets 2.8.9 and the ASIO SDK. All went well with no errors and Audacity comes up without bother. However, under the Generate menu, there's no "click track" as there is on the download version, stable and beta.
Does anyone know how I might debug this? It's my first time compiling Audacity so I'm not clear on how to debug.
Thanks for any help.
Re: Generate -> Click Track [ 1.3.6a6 ]
Post by steve » Fri Oct 03, 2008 1:35 pm
Do you have "clicktrack.ny" in your Audacity plugins folder?
smarmit
Post by smarmit » Sat Oct 04, 2008 1:01 am
Yes, it is there. Maybe there's a way that plug-ins can be built separately? I built the full solution with the "Release" configuration.
smarmit
Post by smarmit » Sat Oct 04, 2008 1:04 am
Ahhh... I see what you mean now. I just found a compile note that says to copy "nyquist" and the "plug-ins" folder to the build output folder. I thought you were asking about it being in the 'src' area. Once I copied nyquist and plug-ins to my release dir, it all worked
Thanks a lot!
distancehasaway
Post by distancehasaway » Sun Apr 29, 2012 6:41 pm
Hello. I have a similar problem. I have 2.0.1 alpha, and when I go to Generate -> Click Track, I also get nothing. I would look in my Audacity plugins folder, but I'm not sure where that is. I have Mac OS X, and the manual told me that it's probably in the Applications folder, but it's not there. Are there any Mac users who might know where I can find the plugin folder? Thanks in advance!
Post by steve » Sun Apr 29, 2012 7:17 pm
distancehasaway wrote: I have 2.0.1 alpha, and when I go to Generate -> Click Track, I also get nothing.
If "Click Track" is listed in the Generate menu then Audacity has found the Click Track plug-in.
Are you saying that "Click Track" is not in the Generate menu or that it is the menu but it doesn't work?
distancehasaway
Post by distancehasaway » Sun Apr 29, 2012 7:34 pm
steve wrote: If "Click Track" is listed in the Generate menu then Audacity has found the Click Track plug-in.
Sorry if that wasn't clear. "Click Track" is not in the Generate menu at all.
Post by steve » Sun Apr 29, 2012 11:11 pm
distancehasaway wrote:Hello. I have a similar problem. I have 2.0.1 alpha, and when I go to Generate -> Click Track, I also get nothing. I would look in my Audacity plugins folder, but I'm not sure where that is. I have Mac OS X, and the manual told me that it's probably in the Applications folder, but it's not there. Are there any Mac users who might know where I can find the plugin folder? Thanks in advance!
Did you build Audacity from the source code?
How exactly did you install Audacity 2.0.1?
distancehasaway
Post by distancehasaway » Mon Apr 30, 2012 2:13 am
steve wrote:Did you build Audacity from the source code?
Sorry, I meant 2.0.0. I downloaded it from audacity.sourceforge.net.
Post by steve » Mon Apr 30, 2012 2:54 pm
This topic is about compiling from the source code.
I don't use Macs so I don't think that I can help you. For help with a normal installation of Audacity 2.0 you would be better to ask the Mac guys by starting a new topic on the Mac OS X board here: http://forum.audacityteam.org/viewforum.php?f=47
