Audacity crashes when opening already recorded Aiff
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
kenyatta
Post by kenyatta » Tue Jun 05, 2012 7:01 pm
I recently recorded a few LPs using Audacity 2.x for the first time. I have been using the program to rip cassettes and LPs for at lease 4 years now. Recently, i started exporting my rips as .Aiff files to save space over saving them as projects. However, latest version of Audacity, crashes almost every time i open an Aiff file to edit. Anyone else having the same problem? i'm considering going back to the Beta version as i have a dozen more LPs to rip.
Thanks.
Mac Mini 4 GB memory Running OSX Lion
Re: Audacity crashes when opening already recorded Aiff
Post by kozikowski » Tue Jun 05, 2012 7:56 pm
WAV files are recognized by both Mac and Windows and it's the Audacity default. I haven't used AIFF in years on either of my Macs. The only shortcoming is AIFF handles metadata better than wave. I think that's the only difference past some unimportant data structure issues. The musical quality is the same.
Can you create a five second AIFF that guaranteed crashes your Audacity and post it here on the forum?
http://forum.audacityteam.org/viewtopic ... 49&t=64936
billw58
Post by billw58 » Wed Jun 06, 2012 1:05 am
I use AIFs exclusively (for the metadata). I've never had a problem.
-- Bill
kenyatta
Post by kenyatta » Wed Jun 06, 2012 12:16 pm
billw58 wrote:I use AIFs exclusively (for the metadata). I've never had a problem.
-- Bill
I started using Aiffs exclusively since the beta version and never had any problems. I did a clean install of Audacity 2, but it still crashes. Thanks.
kenyatta
Post by kenyatta » Wed Jun 06, 2012 12:20 pm
kozikowski wrote:WAV files are recognized by both Mac and Windows and it's the Audacity default. I haven't used AIFF in years on either of my Macs. The only shortcoming is AIFF handles metadata better than wave. I think that's the only difference past some unimportant data structure issues. The musical quality is the same.
Here's a 45 sec sound file. Thanks.
http://www.sendspace.com/file/pth4yo
PGA
Post by PGA » Wed Jun 06, 2012 5:51 pm
When I followed that link, I was invited to download an EXE file. Please don't take offence but I don't know you, I don't know that site and I didn't recognise the software product name. Since I know of no valid reason why an audio file has to wrapped within an EXE file, I am leaving well alone.
billw58
Post by billw58 » Wed Jun 06, 2012 5:55 pm
That file imports fine for me. Audacity 2.0.0 OS X 10.7.2.
In the File Import dialog, what have you chosen in the "Format" drop-down menu below the file list.
Try resetting your preferences. http://manual.audacityteam.org/man/Preferences#reset
-- Bill
kenyatta
Post by kenyatta » Fri Jun 08, 2012 12:56 pm
PGA wrote:When I followed that link, I was invited to download an EXE file. Please don't take offence but I don't know you, I don't know that site and I didn't recognise the software product name. Since I know of no valid reason why an audio file has to wrapped within an EXE file, I am leaving well alone.
Not my doing.
kenyatta
Post by kenyatta » Fri Jun 08, 2012 12:58 pm
billw58 wrote:That file imports fine for me. Audacity 2.0.0 OS X 10.7.2.
-- Bill
Thanks, I'll try that.
Ken
dannykauf
Post by dannykauf » Fri Sep 27, 2013 10:10 pm
I'm having the same issue. Mac OsX 10.8.5
