Unable to record from Youtube.
Arnak
Post by Arnak » Tue Jun 05, 2012 4:44 pm
Hi,
Bit of a strange one this, I have upgraded to the latest version 2.0 but while I can here the sound from youtube perfectly it will not record in Audacity.
I checked the log file and get this as soon as I open Audacity :-
Audacity 2.0.0
17:42:10: Error: Couldn't find symbol 'MainPanelFunc' in a dynamic library (error 127: the specified procedure could not be found.)
17:42:25: Trying to load FFmpeg libraries...
17:42:25: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
17:42:25: Looking up PATH environment variable...
17:42:25: PATH = 'C:Program FilesMozilla Firefox;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:Program FilesATI TechnologiesATI.ACECore-Static;C:Program FilesHI-TECH SoftwarePICCLITE9.60bin;C:Program FilesQuickTime AlternativeQTSystem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesCommon FilesAcronisSnapAPI;C:PROGRA~1DISKEE~1DISKEE~2;c:Program FilesMicrosoft SQL Server100ToolsBinn;c:Program FilesMicrosoft SQL Server100DTSBinn'
17:42:25: Checking that '' is in PATH...
17:42:25: FFmpeg directory is in PATH.
17:42:25: Checking for monolithic avformat from 'avformat-52.dll'.
17:42:25: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
17:42:25: Loading avutil from 'avutil-50.dll'.
17:42:25: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
17:42:25: Loading avcodec from 'avcodec-52.dll'.
17:42:25: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
17:42:25: Loading avformat from 'avformat-52.dll'.
17:42:25: Error: Failed to load FFmpeg libraries.
17:42:25: Error: Failed to find compatible FFmpeg libraries.
Obviously there is a problem there/ :shock:
I have tried downloading and installing twice now with no change in the log.
Any advice please?
Arnak
Re: Unable to record from Youtube.
Post by kozikowski » Tue Jun 05, 2012 8:04 pm
YouTube is Flash and streaming. There is no file. You might be able to configure your computer to record live internet audio.
http://manual.audacityteam.org/help/man ... puter.html
Arnak
Post by Arnak » Tue Jun 05, 2012 8:59 pm
Hi,
Thanks for the reply.
A further update, please ignore the log file as I found an answer regarding that as being normal due to a plugin or similar that is not required.
I am using VIsta which I did neglect to mention.
As regards to a file, yes I agree that it is streaming from youtube and that normally works flawlessly with Audacity.
In fact I do not think the problem is with Audacity at all but something that has changed on my PC as my other PC on an earlier version of Audacity works perfectly with you tube as usual. :)
What I am asking for help with is what else could cause Audacity to not record in that manner as I have checked the recording settings and they appear to be correct when checked against the sound settings regarding the input selection.
The sound plays perfectly on the pc but for some reason is not being picked up in Audacity. :?
So any advice on how I should go about finding what is wrong would be helpful.
Arnak
Post by steve » Tue Jun 05, 2012 9:11 pm
Arnak wrote:What I am asking for help with is what else could cause Audacity to not record in that manner as I have checked the recording settings and they appear to be correct when checked against the sound settings regarding the input selection.
What settings do you currently have?
Arnak
Post by Arnak » Tue Jun 05, 2012 9:21 pm
Hi,
Settings are :-
Windows direct sound, Speakers c - media, Rec Playback IDT sound, 2 stereo.
The rec playback is the default in windows.
I bet somehting is wrong in the pc but what?
Arnak
Post by steve » Tue Jun 05, 2012 9:29 pm
Try recording using "Sound Recorder". This is a very basic tool but it will establish if the problem is with Audacity or with your computer sound setup.
If you have trouble recording with Sound Recorder, see if any of this helps: http://answers.microsoft.com/en-us/wind ... b=MoreHelp
Arnak
Post by Arnak » Tue Jun 05, 2012 9:50 pm
Hi,
Thanks for the tip, I downloaded and used freecorder, that solves the problem as I can them put the files into audacity to work on. :D
Arnak
