Need permission to transfer to mp3?
joypick
Post by joypick » Tue Jun 05, 2012 12:42 am
I just got a turntable with an older version of Audacity and it wouldn't let me import to mp3 or download LAME. I downloaded the newer verison of Audacity, replacing the old one, and when I try to transfer a track, it says I don't have permission to do this. How can I finally get this to work? PLEASE help me!
thor21344
Re: Need permission to transfer to mp3?
Post by thor21344 » Tue Jun 05, 2012 3:14 am
First try logging on as administrator, second, you said that it would not let you D/L LAME, did you get it D/L'ed? Marty
joypick
Post by joypick » Tue Jun 05, 2012 4:06 am
How do I log in as administrator? I tried to do this with the one file I used audacity for before changing over. Should I record it again, then try it? I'm not sure if LAME downloaded automatically with Audacity 2.0, because I get the new message this time.
joypick
Post by joypick » Tue Jun 05, 2012 5:01 am
I tried it with a new recording and it still said I needed permission.
thor21344
Post by thor21344 » Tue Jun 05, 2012 8:20 pm
you have to install LAME after you D/L it. If it is installed then you will usually have an ICON for it on your desktop, to run as administrator you have to right click on the Audacity ICON and click run as administrator. Marty
joypick
Post by joypick » Tue Jun 05, 2012 8:49 pm
Problem solved. Thank you so much!!! :)
joypick
Post by joypick » Tue Jun 05, 2012 8:51 pm
One more quick question- How do I transfer the mp3 file to my itunes?
Post by steve » Tue Jun 05, 2012 9:13 pm
joypick wrote:One more quick question- How do I transfer the mp3 file to my itunes?
See here: http://manual.audacityteam.org/man/Samp ... _to_iTunes
joypick
Post by joypick » Tue Jun 05, 2012 11:28 pm
Thanks again! This is going to be an enormous project.
