Dear All,
I made a short recording at a concert I attended recently - while the vocals and instruments are distinguishable, I'd like to see if there is anything at all possible to clean up the audio quality as much as possible.
I have attached a sample for your expert ears - any ideas what I can do?
The original recording was made in AMR format, but when making this snippet, it exported to mp3 format.
Regards,
childofsai
Cleaning up Audio Recording
childofsai
- Attachments
- hari snippet.mp3
- (498.38 KiB) Downloaded 105 times
Re: Cleaning up Audio Recording
There's not much you can do as the recording is fairly low quality and you can't put back what is missing.
You can make the sound a little less "muddy" with the Equalization effect. http://manual.audacityteam.org/man/Equalization
