Unable to record
bigjet7
Unable to record
Post by bigjet7 » Mon May 28, 2012 11:51 am
Whenever I select the record button get a message "Error while opening sound device. Check the input device setting and project sample rate".
What does this mean, and how to correct?
waxcylinder
Re: Unable to record
Post by waxcylinder » Mon May 28, 2012 1:50 pm
