sound activated recording
marcellusclay
Post by marcellusclay » Sat May 26, 2012 3:50 pm
I am making a recording with a microphone with Audacity.
The recording has to be sound activated, but after the recording has started it has to continue even in the pieces where there is no sound untill I press stop.
That does not seem possible.
The recording stops as soon as the sound is below the treshold.
I have tried to adjust the treshold but its painstaking and does not do the job.
Even if i get it working, in another environment with more or maybe less ambient sound the work has to be done agian.
Is there a way around this and if not: maybe a suggestion for the programmers.
billw58
Re: sound activated recording
Post by billw58 » Sat May 26, 2012 5:09 pm
No, Audacity can't do what you want. Sound Activated Recording works as you describe and cannot be changed (without reprogramming) to start on detection and then continue forever.
Noted as a feature request.
-- Bill
