hi gang
i heard u can use audicity to downloading stuff from places like youtube..how do u do this?
lenny
need help with audacity
coonsanders
Re: need help with audacity
It won't do a thing to the video, but it will slow down the audio.
If you manage to capture a YouTube video, split apart the video and sound tracks and open the track in Audacity. You can use the "Change" tools.
Effect > Change Tempo.
Effect > Change Pitch.
Effect > Change Speed.
coonsanders
thanks..
