Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Shohreh
Post
by Shohreh » Tue May 22, 2012 9:41 am
Hello
I'm using 2.0.0 on XPSP3 and have a couple of questions:
- It takes about 30s to load Audacity because of all the DLL's in plug-ins: If removing DLLs is the solution so Audacity loads faster, which DLLs can I safely remove?
- Last night, I left Audacity running so it could record a 45mn radio show off the sound-card since it would just stop recording once it no longer had any disk space. It did work, but I was wondering if there were a less medieval way to have Audacity stop recording after X minutes?
Thank you.
Shohreh
Post
by Shohreh » Wed May 23, 2012 10:42 pm
Thanks for the tip.
waxcylinder wrote:BTW if you're running out of disk space as soon as that then you're seriously out of room. You need to offline or delete some files and then defrag the disk.
I had enough disk space. I simply went to bed leaving Audacity running because I didn't know it could be configured to stop recording after a certain amount of time. Poor man's timer
