RECORDING & SOUND WAVES
Good evening,
I just purchased the Crosley turntable w software V2.6. I have XP and installed from the exe.
When recording an album to my PC/Audacity, the Audacity software screen reflects a straight line instead of the soundwaves. Please advise on what the error is.
Re: RECORDING & SOUND WAVES
There is no "version 2.6" of Audacity.
If you mean "version 1.2.6" then that is an old (obsolete) version and you should upgrade to the current 2.0 version: http://audacityteam.org/download/
These Tutorials should help to get you started:
http://manual.audacityteam.org/manual/h ... to_cd.html
Sorry. The CD is Crosley USB turntable and it says version 2.6. I did remove the CD version and downloaded from your site and the problem still happened.
Perhaps a misprint or perhaps they are referring to other software on the disk?MOLLYCULE wrote:The CD is Crosley USB turntable and it says version 2.6.
The Audacity version for any installed Audacity can be checked by looking in "Help menu > About Audacity".
See the tutorials that I linked to. If you get stuck please give as much detail as possible about your set-up, what you are doing, what you have done, and what the problem is (we can't see your computer or what you are doing, so the more detail the better).MOLLYCULE wrote:and the problem still happened.
Steve,
I will get back to you after following your instructions.
If I have the same problem, I will include a snapshot of my screen as well.
Thank you for your time.
You're welcome, and good luck.
Good evening Steve,
I've read your link of instructions, uploaded the version 2.0 and when I clicked the record icon I recieved and error msg. See the attached screen print and also advise if the input & output are correct.
Thanks
Thanks
- Attachments
- AUDACITY1.JPG (49.23 KiB) Viewed 1971 times
I had that same problem with a USB Turntable and changed my input to USB AUDIO CODEC It probley not the right thing to do but at least give it a try AS A LAST RESORT. you might get lucky Marty
Thanks thor21344, that is the right thing to do.thor21344 wrote:changed my input to USB AUDIO CODEC It probley not the right thing to do
The Input must be set to the device that you are recording from (the Crosley USB turntable)
The Output must be set to the device that you play back on (the Sigmatel sound card).
As I previously wrote, this is covered in this tutorial: http://manual.audacityteam.org/manual/h ... ables.html
Those options are not listed in the drop down lists. see screen print and advise,
Thank you!!!
Thank you!!!
- Attachments
- AUDACITY2.JPG (81.28 KiB) Viewed 1912 times
