I need to increase my audio output volume
mellowjohnny
Post by mellowjohnny » Mon Sep 29, 2008 1:55 am
I used for the first time...and created a audio track - mono using the std settings
44000, 32-bit
I had my output vol. set on 5
microphone vol set at 9
I then exported as mp3
I downloaded and put on ipod and i made audio cd and i played on computer.
In all cases I have to turn the vol to the absolute highest level to hear it.
How can I increase the volume when playing on ipod or cd?
thank you for your assistance.
Re: I need to increase my audio output volume
Post by steve » Mon Sep 29, 2008 2:53 am
Assuming this is a single track recording:
Before you do the final "Export" step, select "Normalize" from the effects menu.
Tick check both boxes, and enter the number 1 in the text box, then click OK.
Unless there are any loud clicks or thumps spoiling your recording, you should now see the overall volume level is close to maximum.
If you have multiple tracks, play the project and watch the playback meters - adjust the volume sliders on each track as necessary.
mellowjohnny
Post by mellowjohnny » Mon Sep 29, 2008 4:17 pm
Ok, thanks I will try that.
Do I need to put the volume output at max setting
and the microphone input at max setting?
Also I read when exporting to mp3 to change to 16 bit from the 32 bit that i used to record---is this necessary?
thanks,
Post by steve » Mon Sep 29, 2008 5:55 pm
When you record, you should set the levels in the Recording levels in the Windows Mixer (loudspeaker icon near to the system clock) so that you have a strong, but not overly loud recording.
Here is a screen shot of three stereo tracks:
The top stereo track has been recorded too quietly, the middle track is too loud and will be badly distorted, the bottom track is about right.
After the "good" recording has been normalized to -1 dB it will look something like this:
mellowjohnny wrote:Also I read when exporting to mp3 to change to 16 bit from the 32 bit that i used to record---is this necessary?
No that's not necessary for MP3's. LAME (the mp3 encoder) will automatically make any bit depth changes that are necessary.
If you want to make an audio CD, then you should export as 16 bit 44100 Hz WAV (Microsoft PCM) format.
