ImportLabels script command not working?
Audio software developers forum.
bullyellis
Post by bullyellis » Wed May 02, 2012 6:29 pm
Hello again,
Using name pipes and scripting I entered the following command:
GetAllMenuCommands: ShowStatus=true
This worked as desired and I received a list of all menu commands and their current status.
The command I am interested in is : "ImportLabels: ENABLED"
I am trying to import some labels, C:abc.txt, it is formatted correctly as I can import it using the mouse, but am having trouble getting it to work over named pipes and a script.
I have tried the following
MenuCommand: ImportLabels=C:abc.txt
and a bunch of other derivations. Does anyone know the script command for importing a label over named pipes? Is this possible ?
billw58
Re: ImportLabels script command not working?
Post by billw58 » Wed May 02, 2012 6:46 pm
I''ve never used mod-script-pipe and only know what is on this page: http://manual.audacityteam.org/man/Scripting
From that documentation it seems you cannot pass a parameter with MenuCommand.
Since you have compiled Audacity with mod-script-pipe, perhaps you'd be interested in extending it? If so, you might want to ask on the Audacity Developers list.
Go to https://lists.sourceforge.net/lists/lis ... city-devel to sign up for that list.
-- Bill
