Flac files cause Audacity to crash
Help for Audacity on macOS.
bleakley
Post by bleakley » Tue Apr 17, 2012 10:02 pm
Version 2.0.0
OSX 10.6.8
Audacity keeps crashing when I try to apply an "export WAV" chain to Flac files.
Has anyone else run into this problem?
Bleakley
Reason: topic renamed to match problem
bleakley
Re: Applying chains to Flac keeps crashing Audacity
Post by bleakley » Wed Apr 18, 2012 12:01 am
I installed from DMG.
Bleakley
Post by steve » Wed Apr 18, 2012 12:13 am
Do the FLAC files open OK in Audacity if you import them one at a time rather than using a Chain?
bleakley
Post by bleakley » Wed Apr 18, 2012 12:19 am
No, it crashes when I open the individually, too.
Here is the crash report from the chains -
Process: Audacity [82289]
Path: /Applications/Audacity (2.0.0)/Audacity.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 2.0.0.0 (2.0.0.0)
Code Type: X86 (Native)
Parent Process: sh [82286]
Date/Time: 2012-04-17 20:22:52.304 -0400
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 5622095 sec
Crashes Since Last Report: 8
Per-App Interval Since Last Report: 296 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: B07EEF9D-678F-4515-87C5-7857579C2443
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000010e0ffe
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0xffff0f0e __memcpy + 1902
1 com.apple.HIToolbox 0x9aae7404 CArray::ReplaceElements(long, long, long, void const*) + 132
2 com.apple.HIToolbox 0x9ab0c052 CUnicodeTextension::UnicodeReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 1904
3 com.apple.HIToolbox 0x9ab0c509 CUnicodeTextension::ReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 101
4 com.apple.HIToolbox 0x9aafd5cd CReplaceTextCommand::DoMainAction() + 67
5 com.apple.HIToolbox 0x9aafd035 CTextensionEditCommand::DoIt(short*) + 29
6 com.apple.HIToolbox 0x9aafc920 CTextensionCommand::Execute(short*) + 54
7 com.apple.HIToolbox 0x9ab029c9 OpaqueTXNObject::ExecuteCurrCommand() + 113
8 com.apple.HIToolbox 0x9ab02f11 OpaqueTXNObject::NewCommand(short, AttrObjModifier const*, TKeyDownParams*, TReplaceParams*) + 1061
9 com.apple.HIToolbox 0x9aaf0030 DoSetDataCommand(OpaqueTXNObject*, unsigned long, unsigned long, TReplaceParams*) + 299
10 com.apple.HIToolbox 0x9aaf7fd3 TXNSetData + 683
11 Audacity 0x00418fa5 wxMacMLTEControl::SetTXNData(wxString const&, unsigned long, unsigned long) + 165
12 Audacity 0x004190b3 wxMacMLTEControl::WriteText(wxString const&) + 195
13 Audacity 0x00418c98 wxTextCtrl::WriteText(wxString const&) + 168
14 Audacity 0x004c5a99 wxLogWindow::DoLogString(wchar_t const*, long) + 137
15 Audacity 0x00531dc6 wxLog::DoLog(unsigned long, wchar_t const*, long) + 342
16 Audacity 0x004c8083 wxLogWindow::DoLog(unsigned long, wchar_t const*, long) + 99
17 Audacity 0x00037bbb wxLog::OnLog(unsigned long, wchar_t const*, long) + 235
18 Audacity 0x005315c1 wxVLogMessage(wchar_t const*, char*) + 113
19 Audacity 0x0053163b wxLogMessage(wchar_t const*, ...) + 27
20 Audacity 0x001277a6 Importer::Import(wxString, TrackFactory*, Track***, Tags*, wxString&) + 1734
bleakley
Post by bleakley » Wed Apr 18, 2012 12:20 am
And here is the crash report from opening them individually -
Process: Audacity [82386]
Parent Process: sh [82383]
Date/Time: 2012-04-17 20:25:33.823 -0400
Report Version: 6
Interval Since Last Report: 5622248 sec
Crashes Since Last Report: 11
Per-App Interval Since Last Report: 339 sec
Per-App Crashes Since Last Report: 6
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000017ffff0
0 libSystem.B.dylib 0xffff0f32 __memcpy + 1938
20 Audacity 0x001273ea Importer::Import(wxString, TrackFactory*, Track***, Tags*, wxString&) + 778
billw58
Post by billw58 » Wed Apr 18, 2012 1:07 am
Well, it's not chains that's the problem, it has something to do with importing a FLAC since the crash reports are identical. It seems the crash happens while Audacity is attempting to write a message to the Log window.
FLAC import does not rely on an external library (such as LAME or FFmpeg), so the problem is not in that area.
All I can think of is resetting your preferences.
Quit Audacity if it is running.
In <yourhome>/Library/Application Support/audacity
find the file audacity.cfg
Open it in TextEdit and replace the entire contents with this singe line:
NewPrefsInitialized=1
Save the file without changing the extension.
Start Audacity and see if you can import a FLAC file.
-- Bill
bleakley
Post by bleakley » Wed Apr 18, 2012 2:20 am
Doesn't work. Keeps crashing over and over. I tried chains, importing and opening, all to the same result. I guess I'll try re-installing. This is one of the main things I use Audacity for, so I hope I can fix it!
bleakley
Post by bleakley » Wed Apr 18, 2012 2:41 am
Tried re-installing and restarting. Doesn't work. Audacity just won't accept FLAC from me anymore :p
Any other ideas out there?
Bleakley
Post by Gale Andrews » Wed Apr 18, 2012 5:09 am
Do the names of these files have other than A - Z characters and numbers? If not, can you try renaming them like that?
If that does not help, are the files small enough that you can upload an example somewhere from where we could download it? Here are some sites you could upload to:
http://www.yousendit.com
http://www.sendspace.com
http://minus.com/
https://castle.so/
edgar-rft
Post by edgar-rft » Wed Apr 18, 2012 12:50 pm
I don't know how much this applies to current OS X versions, but on my old Mac (until OS X 10.3.9), there was a Mac system configuration file under:
  • [user]/Library/Preferences/net.sourceforge.audacity.plist
Whenever I had "mysterious" problems with Audacity, I deleted this file, and my problems disappeared. This file was not deleted by a new installation of Audacity, but it was automatically re-created (without the misfunctional behaviour) at the next start of Audacity. In case of doubt search for "audacity.plist" in the Mac Finder, but I dont' know if and where this file still exists under current OS X versions.
- edgar
