no record from in laptop audio
chopper63d
Post by chopper63d » Tue Apr 17, 2012 3:09 pm
im trying to chop mix edit 3 songs into a 3 min songs for a dance that my friend wanted to mix for her.
im using dj zulu software to mix fade in and out from the 3 songs. but when i try to use audacity to record what im mixing, audacity doesnt pick up the audio that im record. im not using any kind of mics. i tryed taking the stereo in mono in options but nothing. im doing on my laptop. ive done this on a desktop no problem. but im having that problem with my laptop
Re: no record from in laptop audio
Post by kozikowski » Tue Apr 17, 2012 4:21 pm
That's "Recording audio playing on the computer." Your software doesn't let you export or save a sound file?
The Line-Out (headphone) connection on a Windows laptop tends to not match the Mic-In. They're not mirrors of each other. On a desktop machine, you can get Line-In and Line-Out and use those as a desperation move. Anyway, see if any of this works.
http://manual.audacityteam.org/help/man ... puter.html
Some newer Windows laptops will not allow you to record yourself. For them, you need extra software such as Total Recorder.
Post by steve » Tue Apr 17, 2012 5:16 pm
It might be easier to just mix it on Audacity rather than wrestling with "Stereo Mix" recording.
