Audacity 1.2.6 re-installed on new PC (Windows 7)
Dowloaded lame3.99.5-64 from rarewares
Export multiple mp3
Show Adacity where lame_enc.dll can be found
Audacity says: "Could not open mp3 encoding library"
But it's there.
Version problem?
Regards, Ron McLaren
Re: Could not open mp3 encoding library
I doubt you could do anything useful with that combination. Audacity 1.2.6 will not even open on some newer computers. Download and install Version2 along with the associated lame and FFMpeg.
Thanks, Koz.
Ron
Ron
