Saving WAVs
mikethebass60
Saving WAVs
Post by mikethebass60 » Mon Apr 16, 2012 9:01 pm
I'm running Audacity 2 and have run across this problem.
I've recorded a band's live show on 6 tracks of a Zoom R16.
These I can import into Audacity for editing.
I'd like to mover the individual WAVs back to the R16 for mixing.
If I use export this mixes the tracks into a stero mix.
If I use export multiiple this makesd ecah track a stereo track.
Neither of these is what I want.
Can I save an individual track as a WAV?
edgar-rft
Re: Saving WAVs
Post by edgar-rft » Mon Apr 16, 2012 9:34 pm
Switch Audacity under "Edit > Preferences > Import/Export" from "Always mix all tracks to mono or stereo" to "Use custom mix", then use "File > Export Multiple" with "Split files based on: Tracks" and Audacity will save all audio tracks as separate files.
mikethebass60
Re: Saving WAVs
Post by mikethebass60 » Tue Apr 17, 2012 6:26 pm
Many thanks
