Is there a way I can lock two audio tracks together?
reeverecords
Post by reeverecords » Sat Apr 14, 2012 3:45 pm
Hi,
I have recorded a song "Run" By Leona Lewis and I have recorded my friend sing. Before I started to record I imported the instrumentle into audacity and then clicked record so underneath the instrumentle the voice was recorded. But now when i edit the voice it knocks it out of sync with the instrumenlte so the instrumentle is infornt or behind the voice. Is there anyway I can lock the voice and instrumentle together ?
Thanks :!:
Re: Is there a way I can lock two audio tracks together?
Post by kozikowski » Sat Apr 14, 2012 5:15 pm
What does that mean? You were in the studio when she sang?
reeverecords
Post by reeverecords » Sat Apr 14, 2012 5:17 pm
No a cover!
