Hi
I am new to this, but have an urgent need to attempt the following:-
I need to be able to listen to what is being said by others in the background of a recorded telephone conversation.
This would mean eliminating the main 2 voice conversation from the mono track and bringing forward and improving the background noise/conversation.
The file is .wav
The quality is fairly good and is in Mono
I am using Windows XP Op System
Anyone have any ideas?
Many thanks
How do I bring forward the background in a Voice Recording
RoosterReno
Re: How do I bring forward the background in a Voice Recordi
Yes, but not helpful. You can't split apart voices in a mixed recording.Anyone have any ideas?
