I'm working on Audacity 1.3.13-beta (ANSI) from the .exe installer, Widows 7.
I've been editing some music, and what I've been trying to lenghten one note in the song. Copy and paste dosen't do well because of the ''clipping''. What should I do?
Making a note longer in Audacity
Re: Making a note longer in Audacity
For Windows 7 you should be using a "Unicode" version, not the "ANSI" version. I'd recommend that you upgrade to Audacity 2.0 Unicode. You can get it here: http://audacityteam.org/download/windows
The correct download for Win 7 is marked as:
Audacity 2.0 installer (.exe file, 19.8 MB, including help files) for Windows 2000/XP/Vista/7
In the Effect menu look for the "Sliding Time Scale / Pitch Shift" effect.
Instructions for using it are here: http://manual.audacityteam.org/man/Effect_Menu#slide
Thank you!
