have two versions of Audacity on my computer
Hello, it appears that the Audacity beta version and 2.0 are both installed on my computer (Windows 7, 64 bit, downloaded from the installer, I think). Is it safe to uninstall 1.3 or will I lose data or possibly corrupt 2.0? Thank you! Roberta
Re: have two versions of Audacity on my computer
As long as you are happy that Audacity 2.0 is working correctly it is safe to ununstall Audacity 1.3
thanks, Steve! didn't want to lose data - appreciate your help, Roberta
