Lame and FFMpeg, need both?
robbyr
Post by robbyr » Thu Apr 12, 2012 2:23 am
I installed Lame_v3.99.3_for_Windows.exe for Audacity 2.0. Do I also need to install FFmpeg_v0.6.2_for_Audacity_on_Windows.exe? On the download site, http://lame1.buanzo.com.ar/ , it looks sort of like Lame_v3.99.3_for_Windows.exe includes both.
Thanks for your help
Re: Lame and FFMpeg, need both?
Post by steve » Thu Apr 12, 2012 3:52 am
LAME enables Audacity to export MP3 files.
FFmpeg provides Audacity with Import/Export support for various formats including WMA version 2, AC3 and AAC.
See these two pages:
http://manual.audacityteam.org/man/FAQ: ... encoder.3F
http://manual.audacityteam.org/index.ph ... tallffmpeg
robbyr
Post by robbyr » Fri Apr 13, 2012 2:23 am
Thanks!
