can't export audio
chickenman92
can't export audio
I can't seem to get the audio I have recorded to export! And its a project for school in which I need the mp3 format. However my problem is it keeps asking me to download something or other... which I did, but still couldn't get it to export. What should I do?
Re: can't export audio
If you need ot in MP3 format you will need to install LAME. http://manual.audacityteam.org/man/FAQ: ... g-Ins#lame
