how to record Serato with Audacity [SOLVED]
TheX
Post by TheX » Sun Apr 08, 2012 9:49 pm
hello.
I bought the numark N4 and i started to mix in serato dj intro.
I wannt to record a mix but i do not know how to setup the audacity corectly ..
please can someone help me with this ?
Re: how to setup ?
Post by steve » Mon Apr 09, 2012 1:02 am
The first few posts here answer your question: http://serato.com/forum/discussion/576697
TheX
Re: how to setup ?
Post by TheX » Tue Apr 10, 2012 11:06 am
i know its somewhere in serato forum .. but my english is not good enought to understand that.. :/
Re: how to setup ?
Post by steve » Tue Apr 10, 2012 6:44 pm
The recommendation from the Serato forum is to either upgrade to a version of Serato that supports saving your mix, or record onto a separate machine (either a second computer or other recording device such as a mini-disk or cassette recorder).
TheX
Re: how to setup ?
Post by TheX » Wed Apr 11, 2012 8:32 pm
i know the recomendents . but i hawe problem's whith setings
Re: how to setup ?
Post by steve » Wed Apr 11, 2012 9:14 pm
I can't help you with Serato - I don't have it.
Try the Serato help forum, they should be the experts with Serato.
TheX
Re: how to setup ?
Post by TheX » Tue Apr 17, 2012 9:01 pm
ppl from serato forum say me "try ask at audacity forum" :/
Re: how to setup ?
Post by Gale Andrews » Wed Apr 18, 2012 1:18 am
Does your computer have a line-in (blue)? You want to connect the Serato output to line-in then set up Audacity in Device Toolbar to record from line-in.
TheX
Post by TheX » Wed Apr 18, 2012 8:06 pm
yes and i finally set it on.. :) thx for saying me colour of line in :)
