recording Zynaddsubfx sounds in Audacity
soopey
Post by soopey » Mon Apr 02, 2012 10:36 pm
I'm currently trying to figure out a way to make Audacity record whatever i'm playing in Zynaddsubfx.
I'm using windows 7 and since i'm poor (no acutal piano keyboard usb) im using the computer keyboard to play whatever sounds I am playing in Zyn.
So to make the question simple. In a step-by-step process, how do I get Audacity to record the keys I press in Zynaddsubfx?
I've been tryin to figure this out for the past day and its really frustrating me. Help would be appreciated
Re: recording Zynaddsubfx sounds in Audacity
Post by kozikowski » Mon Apr 02, 2012 10:54 pm
Wait, you want to record the keys, or the musical notes?
You can set your computer up to record its own sounds.
http://manual.audacityteam.org/man/Tuto ... e_computer
soopey
Post by soopey » Tue Apr 03, 2012 3:52 am
Ahh, first off thanks for the reply. I should of specified that I want to record the musical notes in audacity whilst i play them in Zyn. but i'll take a look at the link you gave me.
Reason: duplicate post deleted
soopey
Post by soopey » Wed Apr 04, 2012 10:23 am
Oh jeez this is getting annoying. I've followed the instructions to install a VSTi plug-in into audacity but doesn't seem to work. anyone know of any other VSTi plugins i can try that work? Because trying figure out how to integrate Zyn with audacity is getting really annoying. I'm not sure if im even putting the right file in the plugins folder
Post by steve » Wed Apr 04, 2012 1:49 pm
Audacity does not support VST instruments (VSTi) http://manual.audacityteam.org/help/man ... st_install
For recording the Zynaddsubfx in Audacity (on Windows) you need to run the synth separately from Audacity and use Audacity to record all sounds that are playing on your computer (remember to turn off Windows notification sounds so as to avoid recoding "ping - you have new e-mail" and suchlike).
Koz posted the relevant documentation link previously.
