Hello
Audacity is apparently unable to play SWF files. Is there an add-on I could use?
FWIW, I also tried VLC (1.x and 2.x), but it crashes when I load the SWF file.
Thank you.
[2.0.0/Win] Extracting sound from SWF file?
Re: [2.0.0/Win] Extracting sound from SWF file?
The best you can do is install the FFMpeg software. That allows Audacity to recognize and process a very wide range of content, however, if VLC couldn't deal with it, that's not a good sign.
Thanks for the links.
If your computer supports it, you could try playing the SWF file in a suitable player program and then capture the sound from "Stereo Mix".
