can't see the line in option in audio input tab
sgoswam1
Post by sgoswam1 » Sun Apr 01, 2012 7:30 pm
I have installed audacity 2.0.0 in windows vista.
I don't see the line in option under the input tab. I only see micrphone (realtek) and microsoft sound mapper.
Help will be appreciated.
thanks
sumit
Re: can't see the line in option in audio input tab
Post by Gale Andrews » Mon Apr 02, 2012 12:50 am
Enable the line-in in Windows following these instructions:
http://wiki.audacityteam.org/index.php? ... es#vistacp .
Post by kozikowski » Mon Apr 02, 2012 2:33 am
If you have a Windows Laptop, you may not have a Stereo Line-In.
Scroll down to Connections.
http://www.kozco.com/tech/audacity/wind ... rding.html
