I really do not know what to expect. I just downloaded Audacity and have yet to fully read the Manual and actually use the program, however, I did make a small donation and I am excited about the prospects of using Audacity as an audio manipulator for use in Corel Video Studio Pro X4. Can any of you guys direct me to a location where I might discover how Audacity might interface with Corel Video Studio?
Thanks
mfrays12
I'm New
Re: I'm New
It may not need a manual. You read the instructions in your video editor and find out what kind of sound files it accepts. It can probably use Microsoft WAV which is Audacity's default sound format. Record or produce your Audacity sound tracks and export a WAV file which you then import into your video editor for mixing into the show.
I record sound and voice tracks all the time and deliver tracks to the Avid and Final Cut video editors for integration into shows.
Describe what you were expecting to happen.
