Audacity 2.0 does not open Wav-file
OnTour4
Post by OnTour4 » Sun Apr 01, 2012 10:42 am
Hello
I have just installed Audacity 2.0.0 to an old Windows XP from .exe installer. Installation went ok., I suppose, but when I try to open the first file, it does not recognize, that the file is .wav-file. The file was recorded with Windows Media Player.
I tried both Open > and Bring (?) > Audio (ctrl+shift+I) (my program has another language, so I am not sure, if Bring is the right word in English..)
Program gave two warnings:
"Audacity attempted to use FFmpeg to import an audio file, but the libraries were not found" and another:
"Audacity did not recognize the type of the file "E:Ha_T.wav '. If it is uncompressed, try importing it using "Import Raw".
I tried to import the file as a raw file, that seemed to go ok but the speech was played veeeeeeeeeeeeeerrrrrrryyyyyyyyyyyy slowly so you could not understand the words at all.
Please help me :D . Thank you for your help!
billw58
Re: Audacity 2.0 does not open Wav-file
Post by billw58 » Sun Apr 01, 2012 2:11 pm
You need to install FFmpeg. Instructions are here: http://manual.audacityteam.org/man/FAQ: ... Ins#ffdown
The file is not an uncompressed WAV - WAV is just a container and in this case contains a compressed file format.
-- Bill
