Mic in a bucket
Graham King
Mic in a bucket
Post by Graham King » Sun Apr 01, 2012 9:44 am
My Logitech webcam mic seems to be cutting in and prevent me recording properly from Internet radio streams.
The result - it records both the Internet and external sounds from the room - and the finished recording sounds like the mic is in a bucket - dull, flat, slightly echoey (probably because the mic is beneath the speaker shelf!).
I've tried disabling the webcam mic but Audacity then can't find any alternative to record with.
I have used Audacity successfully for many years but recently re-installed Windows and can't get back to the same successful configuration.
Graham
Re: Mic in a bucket
Post by steve » Sun Apr 01, 2012 3:11 pm
To record from the Internet, the best way is to use "Stereo Mix" (if that option is available).
See here: http://wiki.audacityteam.org/wiki/Mixer ... _Issues#cp
waxcylinder
Re: Mic in a bucket
Post by waxcylinder » Sun Apr 01, 2012 3:13 pm
this tutorial from the 2.0 manual should be useful too: http://manual.audacityteam.org/help/man ... puter.html
