Hi Folks,
My set up Laptop, Windows Vista, Audacity 2.
I record on my Zoom R16 and I'm experimenting with importing the tracks into Audacity for processing and editing.
Following earlier advice about adding reverb to a vocal track I add a new track and copy the vocals into the new track then add reverb and mix the two vocal tracks.
A minor irritation and I'm probably missing something. When I add the new track it always appears at the bottom of the exisitng tracks. To move it next to the track it's relevant to I have to use the move track up controls several times. Is there any easier way of doing this.
Thanks
Mike
Adding A Track
mikethebass60
billw58
Re: Adding A Track
Grab the track by the Track Control Panel and drag it to where you want it.mikethebass60 wrote: A minor irritation and I'm probably missing something. When I add the new track it always appears at the bottom of the exisitng tracks. To move it next to the track it's relevant to I have to use the move track up controls several times. Is there any easier way of doing this.
http://manual.audacityteam.org/man/Audio_Tracks#panel
http://manual.audacityteam.org/man/Track_Drop-Down_Menu
-- Bill
Re: Adding A Track
And if you have more tracks than will fit on one screen, use View...Fit Vertically (Ctrl+Shift+F) first to squeeze them all onto the one screen.
mikethebass60
Re: Adding A Track
Thanks,
I have also found out that if I name tracks say Guitar 1, Guitar 2, Vocal 1 , Vocal 1 reverb etc I can use sort tracks to place them in alphabetic order.
Mike
Mike
Re: Adding A Track
Ctrl + shift + c(collapse tracks) is more convenient than ctrl + shift + f(fit vertically), because you can turn back to the previous track stretching state with ctrl + shift + x (expand tracks)
Re: Adding A Track
That's useful to know. Thanks!gasto wrote:Ctrl + shift + c(collapse tracks) is more convenient than ctrl + shift + f(fit vertically), because you can turn back to the previous track stretching state with ctrl + shift + x (expand tracks)
