Hi. First time on the forum although I've been using Audacity in spurts for many years. I am a big Who collector and use it to edit my tapes.
I used Audacity to record a cassette tape of an old Pete Townshend show. After I cut out the tuning up and songs I didn't want, I added labels, normalized and noised reduced.
Then I exported the 18 separate tracks as mp3's. When listening to each an every one, there is a rhythmic "tic, tic, tic, tic" that ruins the cut completely. I treid to export in wav formatl, and I get the same thing. When I listen to the songs within the Audacity program itself, it sounds perfect.
Any ideas on what has happened and what I can do about it?
Thanks,
Dave Schwartz, Commack, NY
Repetitive tick noise in exported mp3 and wav files
Re: Repetitive tick noise in exported mp3 and wav files
Who?
Couldn't resist.
How are you listening to them outside of Audacity?
Does this tick?
http://www.kozco.com/tech/LRMonoPhaset4.wav
It's very short. That was produced in Audacity.
Post two seconds or so of the damage here.
Couldn't resist.
Does this tick?
How do I post the music clip?
Koz, I exported again on a new day and the clips seem OK. Thanks for your interest. But for the future, how do I post clips onto the forum and what is the proper length of the clip?
Dave
Dave
