FFmpeg Version
bcgrtm
FFmpeg Version
Post by bcgrtm » Fri Mar 30, 2012 5:53 am
Will the latest version of FFmpeg (0.10.1) work with Audacity? I am using it to export to M4A.
Re: FFmpeg Version
Post by Gale Andrews » Sat Mar 31, 2012 4:39 am
bcgrtm wrote:Will the latest version of FFmpeg (0.10.1) work with Audacity? I am using it to export to M4A.
Please see http://forum.audacityteam.org/viewtopic ... 23#p172292 .
