Thanks waxcylinder for the reply.
Here is the latest update; in summary, I have been able to use "Import Audio" feature on x86 using the codebase 2.0.0; but the same does not work for ARM.
More importantly, on ARM, I am still not able to make recognise FFMPEG Library.
Here are more details ::
Well, just came across the note at
http://manual.audacityteam.org/man/FAQ: ... tallffmpeg
FFmpeg version information: Audacity 1.3.8 to 1.3.12 inclusive did not compile or work correctly with FFmpeg versions greater than 0.5, and 1.3.13 to 1.3.14 inclusive did not compile or work correctly with FFmpeg versions greater than 0.6. If you are not using the latest version of Audacity, please upgrade.
Thus I downloaded "audacity-2.0.0" and built it on X86 F14. "Import Audio" WORKED !!!
However, when I did the same on ARM, "Import Audio" DID NOT WORK.
Instead, it showed the following error logs on startup ::
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1035
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1192
Expression 'PaAlsaStreamComponent_Initialize( &self->playback, alsaApi, outParams, StreamDirection_Out, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1437
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2105
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3875
Regards,
Ajay
