I'm one of the users that Steve was referring to - I started with an ION iTTUSB but junked it as although the electronics were fine the platter was so lightweight I got lots of wow&flutter (speed variations).
I serviced my old Technics TT and bought a preamp and an external USB soundcard (as the soundcard in my PC is average at best).
I bought the ARTcessories DJ-Pre11 pre-amp: http://artproaudio.com/artcessories/tur ... /djpre_ii/
and an Edirol UA-1EX USB sound card (no longer manufactured).
If I was buying today I would probably get the integrated device that ART makes - the USB Phono Plus: http://artproaudio.com/artcessories/tur ... o_plus-ps/
Its basically the same preamp as the DJ-Pre11 but with an integrated USB soundcard bundled in.
Can't find the audio i/0 tab in preference for recording dev
waxcylinder
Re: Can't find the audio i/0 tab in preference for recording
Re: thanks for the recording advise
I got rid of my Grace digital usb turntable and took your advise and got the ART USB phono plus amp.to hook up to my old turntable. What a difference, so far my recording tracks are balanced and the clipping is no longer a problem.
thanks so much Steve.
Reta
Reta
