Threshold parameter in Transient Mangler
Re: Threshold parameter in Transient Mangler
Post by steve » Thu May 17, 2012 6:51 pm
DickN wrote:Why do so many effect names end with "..."?
Effects that end with "..." have an interface for user settings.
Effects without "..." have no user interface (for example "Fade In" and "Fade Out") and they just do something immediately.
The "..." indicates that there is something to follow (a user interface).
DickN wrote:The only negative I have on it is I wish it didn't clip @ 0dB input, but your writeup does warn us about that. I guess if it were simple to avoid that, it would have been avoided.
Yes, if the input goes over 0 dB the algorithm does very nasty things - worse than hard clipping.
If there is just the odd sample above 0 dB, hard clipping does little harm.
Usually the effect would be used after compression, so that should ensure that the peaks do not exceed 0 dB. If not then the user should Normalize prior to limiting.
The main problem with trying to cope with 0 dB within the effect is that it then becomes very mysterious what the effect is actually doing and can cause surprising effects.
