Windows 7 64 bit
Re: Windows 7 64 bit
Post by steve » Mon Jun 01, 2015 10:57 pm
jmacallen wrote:I have a newer laptop. It is a Toshiba 64 bit device. Is there a version of Audacity that will run on it?
The current version of Audacity runs fine on latest generation 64-bit PCs. Assuming that you are using a current release version of Windows you can find the system requirements here: http://web.audacityteam.org/download/windows
