dither on export (bug 22)
Re: dither on export (bug 22)
Converting from float to int by truncating sounds wrong on many levels
I can't properly understand what truncate means in this context...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
rounding down.bgravato wrote:I can't properly understand what truncate means in this context...
I understand the "idea", my failure to understand is in terms of programming/computing... what could it mean to truncate a float and get an int without float->int conversion?
But never mind I'm just being picky about languistics (Ed influences? hehe)
It's something like:bgravato wrote:what could it mean to truncate a float and get an int without float->int conversion?
Multiply the original 32 bit float value by 2^23 then round down to get the signed 24 bit integer.
In 32 bit float notation, 0 dB is +/- 1
In 24 bit integer notation, 0 dB is +/- 2^23
Multiplying and rounding is not truncating... it's multiplying and roundingsteve wrote:It's something like:bgravato wrote:what could it mean to truncate a float and get an int without float->int conversion?
- Quality Assurance
Those lines were last modified in 2002 (around the time of 1.0.0) when there was no sample format preference. 1.2.0 (2004) had the 24-bit format preference.steve wrote:It looks like that was written at a time when there was no 24 bit option. Has there ever been such a time?Gale Andrews wrote:From ImportPCM.cpp:Code: Select all
// In general, go with the user's preferences. However, if // the file is higher-quality, go with a format which preserves // the quality of the original file. if (mFormat != floatSample && sf_subtype_more_than_16_bits(mInfo.format)) mFormat = floatSample;
Is it possible to be a bit more definitive e.g. by testing this in 1.2.6 and HEAD and comparing sample values like for like?steve wrote:It looks to me like 24 bit files are converted to 32 bit float (surprising perhaps, but perhaps not a "bad" thing), but then on Export to 24 bit, the sample values are truncated to 24 bit. Export should properly convert to 24 bit (with dither if enabled) and not just truncated to 24 bit.
I think all that was about the Manual stating that Audacity "by default" processed internally at 32-bit, when in truth it always does that irrespective of the sample format of the audio - there is no option.steve wrote:@Gale - I vaguely recall some fuss a long time ago about something in the manual that said that converting from 32 bit float to 24 bit integer was done by truncating. Do you remember that? Does it relate to this issue?
Yes, certainly.Gale Andrews wrote:Is it possible to be a bit more definitive
Sadly no, because there was a different bug in early versions of Audacity that caused 24 bit sample values to be calculated incorrectly and that didn't get fixed until well into 1.3.x versions.Gale Andrews wrote: e.g. by testing this in 1.2.6 and HEAD and comparing sample values like for like?
Nyquist code to generate a sequence of every 24 bit sample value (about 6 min 20 seconds duration):
Code: Select all
;; generate ramp with one sample at each 24 bit value
(abs-env
(control-srate-abs *sound-srate*
(pwlv -1 (/ (power 2 24) *sound-srate*) 1)))Nyquist code to read sample values in 24 bit format. All values should be integers. The sample values are displayed with one decimal place just to show that they are integers.
Code: Select all
;; print 24 bit value for x number of sample
(setq x 20)
(setq *float-format* "%1.1f")
(setq output "")
(dotimes (i x)
(setq output
(format nil "~a~%~a" output
(* (power 2 23)(snd-fetch s)))))
(print output)Test results:
1) Generate samples into a 32 bit float track.
The samples test as sequential integer values. Example output from 4min into the track :
Code: Select all
2195392.0
2195393.0
2195394.0
2195395.0
2195396.0
2195397.0
2195398.0
2195399.0
2195400.0
2195401.0Same results as 1 (as expected). Example output from 1 min into the track:
Code: Select all
-5742608.0
-5742607.0
-5742606.0
-5742605.0
-5742604.0
-5742603.0
-5742602.0
-5742601.0
-5742600.0
-5742599.0Sample values are still integers (as they must be for 24 bit) but there is a degree of random variation in the values due to the triangle dither.
Code: Select all
2195392.0
2195393.0
2195394.0
2195394.0
2195396.0
2195398.0
2195398.0
2195399.0
2195400.0
2195400.0Export as 24 bit with dither = none.
Import the track and test the sample values.
The sample values are still integers in sequence as expected.
Code: Select all
2195392.0
2195393.0
2195394.0
2195395.0
2195396.0
2195397.0
2195398.0
2195399.0
2195400.0
2195401.0Export as 24 bit with dither = triangle.
The sample values are still integers in sequence. Dither has not been applied.
Example output from 4min into the track (Note that the sample values are identical to test number 4) :
Code: Select all
2195392.0
2195393.0
2195394.0
2195395.0
2195396.0
2195397.0
2195398.0
2195399.0
2195400.0
2195401.0Code: Select all
;; generate ramp from -0.25 to +0.25
(abs-env
(pwlv -0.25 (/ (power 2 24) *sound-srate*) 0.25)))Generate samples into a 32 bit float track.
The samples test as sequential half-integer values. Example output from 4min into the track :
Code: Select all
548848.00
548848.25
548848.50
548848.75
548849.00
548849.25
548849.50
548849.75
548850.00
548850.25I would have expected integer results rounded to the nearest value but we actually get rounded down values.
Code: Select all
548848.00
548848.00
548848.00
548848.00
548849.00
548849.00
548849.00
548849.00
548850.00
548850.00We would expect integer results with a degree of randomness to the values due to the dither.
We actually get results identical to test 7 - the values are rounded down.
Code: Select all
548848.00
548848.00
548848.00
548848.00
548849.00
548849.00
548849.00
548849.00
548850.00
548850.009) Same as test 8 but with dither = shaped.
Again we get identical results as test 7.
10) Same as test 8 but with dither = rectangle.
Conclusion:
Exporting 32 bit float audio to "signed 24 bit Integer PCM", using "Other uncompressed files" always rounds down the sample values and dither is never applied.
Reason: Correction: replaced "truncated" with "round down".
Results in Audacity 1.3.12 are the same as Audacity 2.0
Results in Audacity 1.3.10 are slightly different - the values appear to be rounded rather than rounded down. Dither is not applied even when selected in Preferences.
Audacity 1.3.4 also appears to round to the nearest. Dither is not applied even when selected in Preferences.
- Quality Assurance
Thanks for the tests.steve wrote:The samples test as sequential half-integer values. Example output from 4min into the track :
7) Export the track from test 6 as 24 bit with dither = none.Code: Select all
548848.00 548848.25 548848.50 548848.75 548849.00
Code: Select all
548848.00 548848.00 548848.00 548848.00 548849.00
So I'm clear, what values would you expect in 7 (what direction should the rounding go in)? And 1.3.10 and 1.3.4 do this?
I tested 32-bit float silence exported to 24-bit WAV with shaped dither set in Preferences in 1.3.2, 1.3.0 and 1.2.6. All WAV's had no dither applied.
So looks like two separate bugs in addition to #22 (or three if you regard 24-bit quality setting importing 16- or 24-bit files as 32-bit as a bug).
Mathematically speaking "rounding" rounds to the nearest integer. Therefore ".00" through ".49" should round down to ".00" and ".50" through ".99" should round up to next ".00"Gale Andrews wrote:...what direction should the rounding go in?...
