Audacity 1.3.14-beta
swendus
Post by swendus » Wed Mar 07, 2012 6:09 am
I have downloaded about 6 different versions of Lame files, none of them are acceptable to Audity 1.3.14-beta. Can someone tell which version will work.
Re: Audacity 1.3.14-beta
Post by kozikowski » Wed Mar 07, 2012 6:19 am
If you found that many lame files, you may be looking in the wrong place.
You need to get Audacity 1.3.14 and lame and FFMpeg from here.
Don't split up the downloads and don't get them from somewhere else.
Just to cover it, which Windows are you using and have you used Audacity 1.2 before? Old Audacity 1.2 setup files can cause problems.
