Setting Up / Learning to use the system
cloch94
Post by cloch94 » Sat Mar 03, 2012 2:42 pm
A few days ago I started to set up the system and at the Audacity control panel on the laptop screen went to Edit/Preferences then Playback and Recording to find the USB Audio Controller. Success. Now I have tried to follow the same route but after Preference a different page appears with these headings-File formats/Spectogram/Directories/Interface/Keyboards/Mouse. I have clicked on one of the options, then OK in the hope that this would clear the unwanted pagebut it appears each time I try. I cannot lose it. I would be most grateful for some advice. Thanks
billw58
Re: Setting Up / Learning to use the system
Post by billw58 » Sat Mar 03, 2012 3:49 pm
From your description is sounds like you are using Audacity 1.2.x. Is that the case?
What computer and operating system are you using? Audacity 1.2.x is not recommended for Windows Vista or Windows 7.
-- Bill
cloch94
Post by cloch94 » Sat Mar 03, 2012 8:40 pm
Bill,
Yes, it is the 1.2 version. I think that I have seen a 1.3 version. Would it be appropriate to download that? Or is there another option. Thanks. cloche94
cloch94
Post by cloch94 » Sat Mar 03, 2012 8:42 pm
Bill,
I forgot to add that I use Windows 7.
billw58
Post by billw58 » Sat Mar 03, 2012 10:21 pm
1.3.14 is recommended for Windows 7.
http://audacityteam.org/download/beta_windows
-- Bill
