Bulk conversion from “.aup” projects to the FLAC format
Robert2
Post by Robert2 » Wed Feb 22, 2012 6:59 pm
Hi,
Is it possible to export several “.aup” files (Audacity Projects) to the FLAC format in batch processing mode from the command-line (or the GUI)?
Thanks in advance.
Robert
Re: Bulk conversion from “.aup” projects to the FLAC format
Post by steve » Wed Feb 22, 2012 7:26 pm
Audacity does not provide any means for batch converting projects. The idea is that you work on the Audacity Project, then finish by Exporting the audio file.
There is some information in this topic about controlling Audacity with external scripting: http://forum.audacityteam.org/viewtopic ... 21&t=63170
Edgar
Forum Crew
Post by Edgar » Wed Feb 22, 2012 8:51 pm
I do this a lot but needed to create a custom build of Audacity. Look at this thread:
http://forum.audacityteam.org/viewtopic ... 21&t=38341
for details. If this sounds like something you want to explore let me know and I will help you.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
