add build date to log
Edgar
Forum Crew
Post by Edgar » Tue Feb 21, 2012 9:56 pm
post 2.0.0
in audacity.h ~ line 41, make beta & "stable" lines end with __TDATE__ like "alpha" does (which adds the BUILD date--and thus some commit version info); also change the trailing - (dash) to a space--it looks better IMVHO:
old:
Code: Select all
#if IS_ALPHA
   #define AUDACITY_SUFFIX wxT("-alpha-") __TDATE__
#elif (IS_BETA)
   #define AUDACITY_SUFFIX    wxT("-beta")
#else
   #define AUDACITY_SUFFIX    wxT("") // for a stable release
#endif
new:
Code: Select all
#if IS_ALPHA
   #define AUDACITY_SUFFIX wxT("-alpha ") __TDATE__
#elif (IS_BETA)
   #define AUDACITY_SUFFIX    wxT("-beta ") __TDATE__
#else
   #define AUDACITY_SUFFIX    wxT(" ") __TDATE__ // for a stable release
#endif
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Re: add build date to log
Post by Gale Andrews » Wed Feb 22, 2012 2:33 am
Edgar wrote:post 2.0.0
Can you say why? There is a policy not to release Audacity with the same version number and different contents (alphas are not strictly "releases").
There may be a better case for having the date of releases shown on the Audacity downloads pages.
Edgar
Forum Crew
Post by Edgar » Wed Feb 22, 2012 8:04 am
Gale Andrews wrote: Can you say why?
The devs would really like to be able to ID the commit revision number for some bug reports. Search Bugzilla for "commit"--I asked if there was a way and got "No, but it sure would be nice". Having the build date on the betas (the "stable" is well known but you might as well have it for the sake of completion) as you already do on the alphas (it is part of the string which gets put at the top of the log) would help pin it down to a single day. That way parsing the commits would be a whole lot simpler.
-Edgar
ragnar.jensen
Post by ragnar.jensen » Wed Feb 22, 2012 7:35 pm
Edgar wrote: The devs would really like to be able to ID the commit revision number for some bug reports. Search Bugzilla for "commit"--I asked if there was a way and got "No, but it sure would be nice".
It is super easy to have Subversion doing it for you.
Code: Select all
svn propset svn:keywords "[Rev|Id|Date|Author|URL]" file
Then add
Code: Select all
$Rev|Id|Date|Author|URL $
to the file and commit.
Code: Select all
$ vi myfile.txt
>   $Rev: $
$ svn ci -m 'Add revision id to file' myfile.txt
$ less myfile.txt
> $Rev: 768 $
Same with the other tags of Id, Date, Author, URL
Ragnar
Edgar
Forum Crew
Post by Edgar » Wed Feb 22, 2012 8:43 pm
ragnar.jensen wrote: It is super easy to have Subversion doing it for you.
I do not see how the user in the field can then tell the dev what the commit revision number is. I think your example adds a revision number to a source file; they want a revision number on the executable and a way the user can report it in a bug report.
-Edgar
ragnar.jensen
Post by ragnar.jensen » Wed Feb 22, 2012 8:54 pm
If the source file in question is AboutDialog.cpp:
About dialog with commit revision
EDIT: Oops, I was too fast! :oops: That will only show the revision when AboutDialog.cpp was last changed.
You'll need svnversion and a bit of external processing to get the global revision number into your file.
Ragnar
Edgar
Forum Crew
Post by Edgar » Thu Feb 23, 2012 12:41 am
That was my thought as well--the devs are not going to edit in something each commit. With adding the build date automatically they get very close and it shows in the Log.
-Edgar
Post by Gale Andrews » Thu Feb 23, 2012 3:44 am
Bugzilla gives too many results for "commit".
My recollection was that Leland and I wanted to add revision number (to *alphas*) and Vaughan (or someone) did not, even if it could be done.
But same question - don't we know the commit number of a release? I do.
billw58
Post by billw58 » Thu Feb 23, 2012 4:39 am
Gale Andrews wrote: But same question - don't we know the commit number of a release? I do.
Certainly, because of the freeze. But there will be nightlies going forward, right? And if those nightlies had at the top of the log the latest commit number, I'd know for sure what I'm testing.
As an aside, I can't see the date/time stamp of commits in Google Code. All I can see is e.g. "Today (26 minutes ago)" or "Yesterday (27 hours ago)". I can infer from that the UTC of the commit, I suppose, but having it displayed would be much easier, and deal with the issue that was raised when I commented on bug 334 http://bugzilla.audacityteam.org/show_b ... id=334#c45 .
-- Bill
Post by Gale Andrews » Thu Feb 23, 2012 6:30 am
Yes, and they will be alphas (I presume) which already have __TDATE__ appended to AUDACITY_SUFFIX.
billw58 wrote:And if those nightlies had at the top of the log the latest commit number, I'd know for sure what I'm testing.
Yes and that was what I was asking for (for the nightlies) but it cannot currently be done. Ed's change does not add the svn revision number anywhere.
billw58 wrote:As an aside, I can't see the date/time stamp of commits in Google Code. All I can see is e.g. "Today (26 minutes ago)" or "Yesterday (27 hours ago)". I can infer from that the UTC of the commit, I suppose, but having it displayed would be much easier, and deal with the issue that was raised when I commented on bug 334 http://bugzilla.audacityteam.org/show_b ... id=334#c45 .
Rather than look on http://code.google.com/p/audacity/source/list , the answer would be to subscribe to audacity-svn_AT_googlegroups.com (or just look at it online ).
