divamover
Post
by divamover » Tue Feb 21, 2012 3:48 am
I just imported a 61 minute long WAV file into Audacity so that I can edit it. After the import, only the first 15 minutes is there.
I didn't get an error message of any kind.
Any settings I need to change so that the entire audio can be imported?
- Site Admin
Post
by steve » Tue Feb 21, 2012 3:55 am
Where did the file come from? Are you sure that it is WAV format, that it is 61 minutes long, and that it is not damaged (corrupt) in any way?
How much disk space is there on your hard drive?
Do you have more than one hard drive?
Have you change any of the settings in the Audacity Preferences?
divamover
Post
by divamover » Tue Feb 21, 2012 4:17 am
Thank you for taking the time to answer my question.
I will investigate the issues you raised.
